Communicating with 1756-RIO
sloverton
Jul 2004
Arkansas
Current system is PLC5/40 communicating with computer optimizer via KT card over channel 1B in adaptor mode. 1B configured for N39:0 thru N39:7 as discrete transfer output source and N39:8 thru N39:15 as discrete transfer input source.
PLC status info is passed to optimizer via N39:0 thru N39:7 and optimizer solution data is passed to PLC via N39:8 thru N39:15.
We are converting this system to a ControlLogix L72 and plan on using a 1756-RIO in adapter mode to communicate with the optimizer. I am unclear on how to configure the 1756-RIO to accomplish this task.
Is this a 1784-KTS, or an ordinary 1784-KT ?
Those cards go way back to the early 1980's and the most popular ones were the 1784-KT Series B (8-bit ISA style) and 1784-KTX (16-bit ISA style), then later the 1784-PKTX Series A and B (5V PCI, then Universal PCI).
The 1784-KTS was a RIO scanner version of the 1784-KTX.
If the Optimizer is really looking at the PLC-5 channel 1B as a RIO adapter, it will have a Rack/Group/Slot and Rack Size definition as well as integer data files associated with it.
My guess is that the PLC-5 is emulating one "Logical Rack" of 8 words. It's probably considered "Rack 0, Group 0".
Ken, you are correct. The PLC5, channel 1B is configured for Rack 1 Group 0 Full rack with N39:0 used for the discrete transfer output source and N39:8 as the discrete transfer input source.
Data placed in N39:0 thru N39:7 is read by the optimizer computer. The optimizer computer then writes the solution data into N39:8 thru N39:15 (8 input words and 8 output words).
What I want to know is can the 1756-RIO perform this task. I am trying to avoid the very expensive re-write of the communications software for the optimizer. Not certain but I think that the computer is using the old 1784 series not sure if it is KTX or KTS. I would hate to leave the old PLC5 processor in the system just to handle comm's but you do what you have to do :)
Hello guys. I have until now always communicated with other machines via either relays or ethernet. Now I must provide a thin client with one INT...
1,849
Dear All Please help me about Below picture problem.PLC not communicating proper.
185
I need to recommend a PC to replace a customer's old Windows 7 computer. The only thing I need to think through is the serial com port to...
21
703
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
462
Hi All I'm trying to connect two zebra printers to th PLC through Ethernet. I can ping the Printer through my laptop connected to the private...
366
