Connection Issue With Digi One IAP & Micrologix 1200
rguimond
Jul 2009
Escuminac
666
I've encountered an issue with a Digi One IAP Serial-to-Ethernet Bridge connected to a Micrologix 1200. It's been operating for several months without issue. This week, however, I can't go online with the PLC. It shows up in RSLinx as being online, with a status of "Remote Run", just like the other PLCs on the network.
Attempting to go online gives and error message "DiagnosticStatus failed: 0x4". Searching this forum and elsewhere suggests reinstalling RSLinx, which I've done without success.
I can successfully go online with this 1200 from another PC through the bridge.
I can also go online with several other 1200s equipped with Digi One IAPs from the same PC I'm having the connection issue with.
Rebooting the PLC and IAP doesn't help.
I seem to remember reading something about adding a suffix to the IP address when configuring RSLinx, but I can't find it.
Any suggestions?
I have the same issue with Digi One IAP network adapter and cant connect using Ethernet Drive.
What i did is download and Install Digi Real Port which is an RS232 port Emulator that connect over your network to the device.
After install it i only setup a DF1 driver on RSLinx, Select the Virtual Port and copy the configuration i have setup for RS232 port on Micrologix because autoconfiguration doesnt work.
Here is the installation guide of the software and how to connect.
http://ftp1.digi.com/support/documentation/90000644_a.pdf
I hope this info is usefull for someone else because after 3 years i think you have another and better solution.
Well, I've decided to start a new project, and like all projects, it has already gone horribly wrong. I purchased a PLC device (supposedly a...
113
Hi all, I'm having an issue with connecting View Studio emulation to a real PLC. I am running View Studio 8.01 on a Hyper-V virtual machine...
262
Hello all. I have a 1769-L16ET-BB1B, LogixDesigner v.34.011, that was brand new, factory sealed. I connected via USB port and downloaded my...
17
2,567
Hi PLC Gurus A customer has requested the connection of a Schneider PowerLogic PM5560 Power Meter to a Rockwell Control Logix PLC. The...
1,930
I am looking to replace a SLC5/05 processor with an AENTR adapter. Configured the rack in a compactlogix. The connection to all of the cards in...
2,315
