Eaton mdf-80-b + cp8-nt + mfd-ta17
nighty
Apr 2014
Finland
Hi
Im relatively new to any plc programming and now i took a challenge to program one to my friends company. im ok with basics, atleast i think i am but one thing has been bugging me for a week or so now.
What im trying to achieve is that when i turn the process on by push button timer turns on and the inverter and keeps running motor for set ammount of time on 100% when time is up it starts another timer and runs motor for 90 minutes but only with 75%. thing i can´t figure out is how i can set analog output automaticly to smaller value when 1st timer runs out? well i have no idea how to set analog output to a value at all without doing it manually from the screen.
any help would be great.
thanks
jarno
You need the DB command, it lets you set a variable to value, or to another variable. You have to be careful when using the DB, you need to trigger the input each time you want the variable to transfer.
Could you go more into detail? i dont quite understand how data block on its own can set output value to something.
like said im new to this stuff.
Below moves 500 in to an analog output. To see the input and output selections for the DB, go to the bottom of the screen where it says Circuit Diagram Elements and select the Parameters tab. Place the DB element at the far right of the screen so that it becomes a coil, trigger the coil with a timer.
The Easysoft program can be a bit confusing to begin with until you find which bit of the screen to look at.
Thanks alot from all the help. this process is now running but i have a little bug in program.
it sounds stupid but i could use help with timers.
i get timers started and analog output set just fine but when process is started and operator pushes stop button timers dont reset and will keep running untill time is up. what is best way to reset timer and its relay?
what i 1st though i would do following
(M#)--------------(R)timer# but that doesnt work, well it kills timer output but doesnt turn of the contact until time is up.
i hope i made my self clear here. any help would be great.
I am guessing that you are using Single Pulse timers. There are two different ways to Reset the timer. Saying it in words would be complicated so have a look at the pictures attached. I02 Resets the timer back to start value so that the timer runs down again. I03 Resets the Timer to Zero and so stops the timer.
Feeling extremely stupid now. how i could not notice that coil function button. meaning that EN--RE--ST option.
thank you very much again. i really have to spend way more time with this easysoft to find out all the tricks.
Hello, I’m new to this forum and if I’m posting incorrectly let me know. I’ve been having an issue I can’t seem to figure out. I’m sure it’s...
126
Hi everyone: we have Baumuller AC drive BM4463 300A 160KW, it drives Baumuller AC motor DST2-315BO54W-020-5-A (90KW;RPM 200; 365V; 215A;83Hz)...
363
Hello everybody, Since my experience is mainly with AB ladder I am having little bit of a problem with EasySoft.. Does anyone knows is there a...
837
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
520
Hey everyone! So I'm trying to get different data from my Eaton DG1 VFD to my studio project. So far my research has led me to something called...
1,565
