FactoryTalk Numeric and Text Display
DamianInRochester
Jan 2011
Rochester NY
1,292
FactoryTalk View ME 5.10.00
I have a String Display object.
I want to concatenate a number and a string to display.
so in "Expression" i have
{numeric tag of type REAL} + "--" + {text tag of type STRING}
During runtime this generates an error
"Unable to activate connection:'my expression'"
Now if I delete the Numeric tag and leave the
then it displays the two dashes and the text just fine
And if I delete the "--" and the STRING tag and leave the
it displays the value of the number just fine
Is there any way to get it to display both??
I should also add that while in the expression editor the "check syntax" button returns valid on the expression that is giving me the error.
Instead choose Object - Drawing - Text
The screen will lead you through setting up the text. If you need a complex frame you can also make one of those then move the Text object on top of it.
Hi there! Sorry to hijack the thread but i have an almost related issue i cant seem to crack.. I have an object (VBA Exposed) that when pressed returns AB_CD_EF (ABCE etc. as example) as a string. I would like to append the controllername and a suffix to this and then use the whole as the expression of a numeric display to indirectly read a tagvalue from the PLC using the VBA, but i seem to get an error when assigning the concatenated string to the .Expression variable of a normal Numeric Display. Any ideas?
Hi guys,
I'm having an issue like this one,
I'm trying to show a real number in numeric display like 2.4
But its showing only 2
In RS Logix its showing real number but not showing on HMI.
any body help please?
How can i show the full reall number in a numeric display.
I'm using Factorytalk view Site edition.
You probably need to check the setting for the number of digits/decimal places for the numeric display.
A quick tip: you select the number of digits, and the number of decimal places, but the number of digits includes the decimal point.
So if you have a value of 2.4:
1 digit, 0 decimal places will read "2"
2 digits, 1 decimal place will read "2" (or more accurately, "2.", but it doesn't show the decimal place)
3 digits, 1 decimal place will show "2.4"
4 digits, 1 decimal place will show either "2.4" or "02.4" depending on your setting for what to do with leading zeroes
4 digits, 2 decimal places will show either "2.4" or "2.40" depending on your setting for what to do with trailing zeroes
5 digits, 2 decimal places, will show "2.4", "02.4", "02.40" or "2.40" again depending on your settings for leading and trailing zeroes.
Hope that helps!
Hey, within FactoryTalk ME I have this numeric input enable button and it is not working. On the HMI, I see the button and the label but when I...
520
I'm working on converting an old PanelBuilder 1200 HMI application into FactoryTalk View ME. The PLC was an old SLC 5/02 with a scanner card for...
1,109
I'm using numeric input enable link tag to PLC DINT type. What I want is for the example in the panel view user will input 350.568 (and shown on...
1,169
I'm trying to display a timer's PRE value in seconds. It works when I hit the test display button, but it displays as ?????? on the HMI and also...
1,835
Hello, Thanks to any help on this issue. Project Info: FactoryTalk ME v11 Panelveiw Plus 7 Compact Logix 5069-L320ER v30 Comms = Ethernet...
4,655
