Greetings Gentlemen!
I'm typing this message in Notepad++ because PLCS.NET knocks me off and my LONG messages disappear. Usually I can hit the back button and find what I typed and copy and paste into a new reply window and post it before I get knocked off again.
QUESTIONS AND COMMENTS:
1. When I invoke TERMF and type !! <ENTER> I get the following reply:
INTERACTIVE MODE ENTERED
type'?' for a list of commands
BUT... according the the "GE_PCM_OPERATING_TIPS_fax02901.pdf" document I should also get this comment: "Welcome to VTOS executive". WHAT does the acronymn "VTOS" stand for? Is it part of VME? European standards? Or what? Do I have an older version of TERMF or something?
2. Comment: I did finally figure out how to invoke the 10 second press of the reset button which takes the PCM out of RUN mode and gives me access again. The only way I have found to monitor the process in real time using the %R tables in Proficy and the scanner gun and TERMF to see the status print to screen is to invoke the program RUN via TERMF. I did it yesterday using MegaBasic but it is more cumbersome (to me)...
3. If I understand correctly, I should be able to edit, make changes, and then put the system back to RUN using a 2 SECOND press of the button. Then 10 SECONDS or more should take it out of RUN and give me COMM back with PCOP wherein I can then invoke TERMF or MB etc....
4. So if I can solve this AUTOSTART PROBLEM on power cycle or LONG PRESS OF THE MAGIC BUTTON, then I should be able to go back and forth between RUN and PROGRAM mode at will. SO HOW DO I... MONITOR THE PGM when it is in RUN MODE with the CPU... that is, a short press of the magic button, program is in RUN, Proficy see it all is well... how do I monitor with PCOP or TERMF or MB without taking it out of RUN first then invoking RUN manually via PCOP-TERMF-MB- et al ... ????
5. This is way too much fun, really brings back fond DOS memories... not joking, I love it.
I'll be back in a while after I resolve this auto run issue using the PCMEXEC.BAT
