Steve Bailey
It looks like a mismatch of either the baud rate or the number of stop bits.
Thanks for this tip as well. This system starts running on power cycle. See the attached .jpg of a screenshot I just did. I had TERMF monitoring, went offline with PROFICY, cycled power, TERMF picked up where it left off monitoring, went back online with PROFICY, SCANNER WORKS.... NUMBERS in the REGISTERS. Is this due to the HARDEXEC.BAT that the PCM created on my first cycle of power? The line of code is: R BASIC.EXE /D1 e848At the risk of confusing things even further, Appendix B of the PCM manual (GFK-0255) gives an example of ladder logic that can command either a soft or hard reset of the PCM module. It can come in handy if you don't want to open the door of the electrical enclosure to push the magic button on the module. Of course you would need an HMI in the system or a spare input point you could use to trigger the command.
