Home Lab advice needed
bfeeny
Sep 2016
South Florida
I am building a home lab using a Wago PLC (750-841) and some I/O modules. My goal is not to be a PLC programmer, but rather to just further my knowledge in that area. I am a software engineer, and work in the Internet of Things space, and interfacing with PLC's and RTU's is of interest to me, and I like to get my hands dirty.
I would like in my lab both digital and analog I/O. I have digital input of 24V and digital output of 24V. I figure I will just hook some 24V lights up to these and some switches, and that would be some good digital components.
What about the analog I/O, any recommendations? I was thinking maybe just connecting a potentiometer/knob to an Analog input, and then looking at the output on a meter. Trying to determine which Wago cards make the most sense, some measure resistance, some voltage and some current.
If anyone has some interesting ideas for basic things that would be useful in a lab please let me know (fan, stack light, etc). I can always add to it, but I wanted to start off with something that would be very useful. My programs will be basic at first as I am just learning Codesys, but I will also be interfacing to an external Modbus Master via software as well.
Thanks for any advice.
As a programmer I'd think that the communications capabilities of the CoDeSys PLCs would interest you most. Since the 750-841 is an older unit I doubt that it works with the SQL library. There are some interesting things in there like FTP support but with the small on-board flash there's not a lot that you can do with it in the real world.
I LOVE these PLCs for writing protocols both over standard serial links and ethernet. They support pointers too which is great for me as a programmer. Finally, be sure to check out the OSCAT library.
Good luck and feel free to ask questions,
Yosi
well you can use the simulator, it is a lot cheaper, and if you want indeed analog i/o i would go for Voltage input and milliamps output.
you can also make a servo motor etc, however they are expensive to start.
PID heater
One of the things for you could be a 4-20 ma temperature in ( RTD to 4-20 ma xmiter) that way you still have spare 4-20 ma inputs for other inputs. You could use this with an output to a solid state relay controlling a heater element with the probe hooked close to it. It would let you program a PID control with pulsed time output. This way you could learn how to tune a working loop.
Hi Everyone, I have a project involving a Beckhoff IPC with Twincat and a Yaskawa servo motor and drive. I'm trying to use the MC_HOME function...
507
I set up a Mitisubishi test system on the bench. Q03UDSPU Q173DCPU MR-J3-40B HF-KP43 HMI is a LS XP50 TTA/KP43 I am trying to use a signed...
398
I'm looking for some starter kits but there aren't so many on the market, so I'm thinking about buying individual components for my needs. I just...
2,469
We have a 5 Ton Rheem A/C unit at home We only run it in the Summertime, and sometimes in the Fall. It does have a habit of blowing fuses at...
18
2,493
Hi All, At work we primarily use Rockwell products and they are pretty good to work with and rock solid for industrial environments. A little...
1,066
