Dobrevjetser
Hi guys,
Recently we had an Indramat tdm 3.2-030-300-w1 that failed (BS led).
We replaced it with a drive with the same partnumber, but now the PWR led is not going on.
When we replace it with a drive from another machine, it works fine.
The only difference i see between the original drive and the replacement, is that the replacement drive has one led more on the display. This is the TÜ led. (for temperature)
All the other is the same. (leds, connections, buttons etc ...)
This drive is guaranteed by my supplier to be good but it is not working. A second drive from the same supplier has the same problem.
If you look at the SN, these drives are older than the one they replaced.
I checked the indramat manuals, and they don't mention any differences between the older and newer drives.
Any idea what could be the problem ?
Thanks,
Marc
Thanks,
Marc
