Inexpensive DC Power Supply
I have a very similar-looking unit that's been running my low voltage circuits on the bench for several years. I can't vouch for that particular one, but at least it's got a cooling fan and a prominent power button.
I haven't looked it up lately, but years ago I was looking for a Weber grill. Rakuten was the cheapest by far. With a little research I found the site was fake. It may be legit now, but I'd be cautious.
My IT dept. browser security is blocking it from me as a malicious site.
When the price of something is too good to be true, there is always a reason.
With DC power supplies, the issue is often the quality of the components and construction methods, plus the "overload capacity" of the PSU. So cheap ones will use a crowbar circuit and if you ever have a surge load, they just turn themselves off. Better ones will have the ability to handle short term surges, such as a solenoid, coil or small motor. I used to do a demonstration of a good quality Puls power supply against a cheap Chinese one (Chint, probably the world's worst choice of brand names), both rated at 5A continuous output. We turned on a machine tool relay with a 24VDC coil. The Chint shut itself down, the Puls didn't even hiccup.
I’ve got a Protek 3006B and love it. Granted it’s a “bit” more expensive however one thing I really like is that not only does it have power “on/off” switch but it also has separate “DC Out” switch. With that, I can power the unit up, set the voltage and max current then turn the DC output on.
If you look at a 'breakdown' on these cheap units, you'll see why they are dirt cheap. The components are garbage. While it will probably do the job, there's no guarantee it's short circuit protection or any other features will work properly. Let's just say I wouldn't keep it plugged in when I'm not home or in the office.
I want to buy used/inexpensive (under $500) PLC hardware and software for personal use/testing. Can any of you suggest the best way to go about...
46
4,852
I need an inexpensive PLC for home automation projects. I only need digital outputs and analog inputs. Pretty simple and slow process. Also, it...
33
12,149
Hello all. I am looking for a very inexpensive PLC in HMI for a very basic control scheme..... a couple of discrete inputs and outputs with a...
18
5,723
I am looking for an inexpensive SCADA sw that can read Modbus TCP/IP. I do not need fancy graphics. I do, however, need datalogging for 30 to 40...
2,700
Hi, I have a project to replace an old BBC Procontic B PLC by a modern PLC on a Flexographic Printer for plastic film. The app is quite simple...
47
21,901
