Let’s practice brain!
Booten - you copied mine.
And curse you Ukranian - you didn't warn me. I proposed this to the electricians in my shop and now they're all standing around scribbling diagrams and scratching their heads and not getting any work done.
Hey Eric - you didn't happen to work in Cleveland OH at any time did you?
I would swear that that is exactly how an annunciator panel I had to connect to and document looked like (even to the wire runs) when we were called in to revise an alarm system at a customer's site!!!
Sorry Bernie. That was unintentional. I just read the challenge and started making drawings with constructor until it worked. I should have read all the replies first.
Bill
about traffic lights
Bitmore said:
Just take my advice and don't ask about a traffic signal program!
By the way, I am caring great idea about traffic lights. Does someone know is this idea new, and I may patent it? The idea is:
For emergency vehicles to get wireless remote control for traffic lights with symbols “STRAIGHT”-“LEFT”-“RIGHT (may be)”. It helps always to enforce green light in desired directions for any emergency vehicle, so traffic never blocks intersections. This will contribute to safety a lot.
Already being done in urban areas. Sometimes with ground loops picking up transponders on vechicles. Also, what about calling for All-red at the intersection. The emer-vehicle can then travel through on the opposite side of road.
good one
Hi Ukrainian
That was a good puzzel. I got caught thinking in THE BOX and never could get out of it. Finally LOOKED at bernie_carlton`s answer. Then i was realllllyy MAD !!!!
because it was so simple,but I guess it`s only simple IF YOU KNOW THE ANSWER :rolleyes:
:site:
Re: about traffic lights
Not... is patented.Have 3-4 similar system, more recent is use RFIDs it date register,after less week publics publication RFID. (For Europe and Americans patented)
Four big city here, it trafic system it aplieed.
----- Bernie Cartoon, goods schematic and strategic. Some problem, refresh image record, I see before.. It traditional problem?
Hello everyone! So basically I have this PF 525 that no matter what I do won’t let me speed down. It always shows 66.66 Hz and the parameters to...
1,243
35 years ago - 167 Souls were lost on Pipe Alpha (Oil Platform in the North Sea) all due to a failed management system See more information here...
820
I have begun using 480VAC power supplies in my panels to keep heat from a transformer out of the panel. This works great if the panel is mounted...
17
4,188
I am deciding on components for a bayed modular enclosure containing multiple VFDs (480V/350A/321Hp each) for a dynamometer. I am concerned given...
1,738
Hi, I am having trouble with the comms within FT view SE v11 (premanent license). I created an HMI program a while back which was working just...
941
