Logix Generic Ethernet Module creates a SINT[400] control tag
seeigecannon
Sep 2018
Colorado
Hello. I am still fairly new to this.
I am playing around with an Indradrive HCS01 controller. I have it talking to my L71 (V33.11) just fine, but it is creating a configuration tag that is a SINT[400]. The drive itself doesn't even use the configuration (in the Connection Parameters area the configuration size is set to 0). The drive is set up as a generic Ethernet module. While Bosch does have an EDS file it doesn't seem to work (and the manual says to create it as a generic module anyway).
My concern is that this is a massive waste of RAM, and while it is not a problem at this time I would rather it stay not a problem if I need to add 10 of these drives.
I am attaching a screenshot of what I am seeing. If anybody has any ideas I would be very grateful.
Config 0 might mean "variable size" I am not sure. Try setting it to 2 bytes.
I know the CODESYS EDS has a two byte config with the text "This is a dummy parameter to satisfy rockwell tools..." so I wonder if Indralogic has the same.
I did try setting the config size to 1 byte before making the post, but the module would show as being faulted until I set it back to 0. I also tried setting the configuration from 110/0 to 102/7 to hopefully just read the input twice and it had the same fault.
Hello all, I need to add a module in logix for an SMC pneumatic valve manifold specifically EX600-SEN3/4. The eds files I add crash the program...
680
​Hello everyone, I triyng to link a Power Module eMB-60R from Robot Adept Viper s650 to CompactLogix, version 19.11 I followed exactly the...
2,655
Hello: I have not been able to get RSLogix 5000 to display expected configuration screen for 1732E configurable armour blocks. Waiting for RA...
39
12,423
Does anyone know the comm format, Assembly Instance and Input/Output size for a Rinstrum C500. It appears their EDS file does not work for RSlogix...
1,613
Hello, I’m communicating a ControlLogix 5000 with a Yaskawa A1000 drive, via a Ethernet 1756en2tr module. I installed the drive interface as a...
3,096
