Low Cost Text display
Ventax
Mar 2009
Kitchener
34
I am looking for some recommendations for a 1 or 2 line by 20 character text display compatible with a SLC 503 or 504. I just want a fault display with no bells or whistles, possibly with 2 buttons but not essential.
Thank you for your input.
Wow, for that price you can get a 5.7" TFT color touchscreen with 5 Function Keys:
http://hmi.beijerelectronics.com/we...AllDocuments/048FBC3F8BABD59AC1257392003635C5
<disclaimer : I work for a Beijer Distributor >
You are right. I overlooked the "possibly with 2 buttons" part. The Vorne displays are great if you need to read at a distance, and are very durable, cheaper replacements for the A/B DL series, and are easy to drive from a parallel output (dc output card w/canned messages) or a serial port.
But if it's going right in front of the operator, buy a full blown HMI for the job...
Paul
HI,
Features:
  • Clear 2x16 character display
  • Turn backlighting on or off with a single command
  • Directly supports ASCII DEC characters 32-127
  • Eight user-definable custom characters
  • Move the cursor anywhere on the display with a single command
  • Baud mode selector and adjustable contrast on the back of the display
Application Ideas:
  • Professional-looking text user interface on any microcontroller application
  • Easy serial debugging without a PC
  • Real-time sensor data output on autonomous robots
Key Specifications:
  • Power requirements: +5 VDC, 20 mA (light off), 80 mA (light on)
  • Selectable asynchronous serial baud rates: 2400, 9600, 19200
  • Dimensions: Approx. 1.5 x 3.15 in (38 x 80 mm) NOTE: Board and LCD size and style may vary
  • Operating temp range: -4 to +158 °F (-20 to +70°C)
$29.99
Bare Bones text display unit. No mounting enclosure included at all. I ran one off of a SLC504 serial port for a few hours just messing around. Get a 5VDC power supply & a little enclosure & your good to go for a hundred bucks or less. They look better in person with the backlight on.
BD
Thanks for the ideas. This is for a fault display on a remote panel. The Optimate looks good. The parallax is tempying but I'm going to test one before adding it to a project
I'm a beginner in the automation field and I've set up an automation system connecting several devices (datalogger, radio, etc.) via Modbus RS485...
230
Hi folks, We have been working on our own controller after many decades of using the "big names". What would your ideal motion-controller be...
48
8,442
I was wondering if any one had an idea how I could implement an amperage reading to the plc. I have two PWM valves which draw about 3 amps...
1,636
Hi guys, May I ask if you know of any device with as few as 3 inputs and capable of ethernet connectivity? I have a project to monitor a number...
20
6,907
Greetings, I am looking for some ideas on low cost VFD's which natively support Ethernet I/P. Looking for 3 phase, 480V, 2h.p. and less. Just...
32
10,704
