M12 Terminating Connector
brandoncosta
Feb 2011
SLC
37
Hi all,
I am using a Kuebler encoder in our machine, it is profibus communicable and has M12 type ports. There are 3 M12 ports, 1st for profibus IN, 2nd for Profibus OUT and 3rd for Power supply.
This encoder is the last node of my profibus network, I m using one M12 connector for Profibus IN, 2nd M12 connector for 24Vdc power supply, now at 3rd M12 profibus out port what type of connector should I use.
As far as I can make out I require M12 terminating connector?
Your thoughts would be appreciated.
I'm not hugely familiar with your setup, but in my limited experience with profibus, yes, it must have a terminating resistor at the end of the network. Sometimes the plugs have a switch on them that can be used to switch a terminating resistor in or out of the circuit - in your case, if there is a "terminating connector" available, I would hazard a guess that yes, that's probably what you need.
Hi - I am searching for an M12 panel receptacles to use for ethernet connections. I see lots of M12 cables that are ATEX / C1D2 rated but nothing...
1,012
M12 sensor plugs are widely used. I'm about making my own CAD symbols for sensor connections, and I'm not sure about including pin #5, which is...
1,538
Hi, Many analog sensors come with M12 connection and up to now for own uses and not so crutial meassurements I have used non shielded M12...
2,056
First thing, do you put labels on all your M12 cables? Second thing, do you label each wire coming out of as flying leads to be used in the...
2,820
Hey Guys, Can anyone help me interface a 5 pin M12 (Pepperl and Fuchs V15-G-10M-PVC) to a DB9 male connection for serial interface between a LED...
2,698
