Maple Systems Display Window Name
JordanCClark
Mar 2007
Michigan
610
Greetings everyone, hope all is well with you.
We've been starting to use the HMI5000 series to replace obsolete HMIs hanging aroung our plant. I can display the current window number, but is there a way to display the window name using a common windows indicator?
Example: If I navigate to window number 123 named 'Setup', I'd like 'Setup' to be displayed.
You would like setup to be displayed where,
On the '123' screen that you just navigated to?
Add a text box on the 123 screen display that reads setup.
Is this what you mean?
Close, but no.
Think of it like a text display that is on a common window that is layered over the base window (number 123 in the example). I want the metadata of the window containing that window's name. This way, I wouldn't have to create a text box for each window.
hello, I have a Maple Systems HMI5103L currently programed and running in conjunction with a AB 2080-LC50-24QWB. everything works fine data is...
721
Good morning, I have a small project coming up and I came across maple systems when looking for a cost effective HMI. What is your opinion on...
1,447
Hello friends, I’ve recently started learning about PLCs and HMIs after I acquired a Wago 750-871 with one digital input card and two digital...
20
5,598
Got a new customer recently that uses Maple System HMI's and CompactLogix L303ER controller I did not do the original programing of this system...
2,341
Hi everyone, New to EasyBuilder 5000. I have one connected to a SCADAPack and is communicating via Modbus TCP/IP. I am using the HMI program to...
1,240
