minimum & maximum analog counts in PLC
kamalice
Oct 2011
23
hi friends,
what is the minimum & maximum counts we get in analog inputs of a PLC.
whether it is same for all models of siemens PLC or it varies depends upon model.
o_O
Depends on the brand, depends on the card - read the manual for the card you have and all will be magically revealed.
It depends on the resolution of the analog card you are using.
"Resolution of an 8-bit binary number is 1 part in 256, values 0 to 255 :
Sometimes the 8-bit number is "signed binary", which still has a resolution of 1 part in 256, but the numeric range is -128 to +127
Resolution of a 12-bit binary number is 1 part in 4096, values 0 to 4095
Sometimes the 12-bit number is "signed binary", which still has a resolution of 1 part in 4096, but the numeric range is -2048 to +2047
Resolution of a 16-bit binary number is 1 part in 65536, values 0 to 65535 : Sometimes the 16-bit number is "signed binary", which still has a resolution of 1 part in 65536, but the numeric range is -32768 to +32767
Resolution of a 32-bit binary number is 1 part in 4,294,967,296, values 0 to 4,294,967,295
Sometimes the 32-bit number is "signed binary", which still has a resolution of 1 part in 4,294,967,296, but the numeric range is -2,147,483,648 to +2,147,483,647"
taken here:
http://www.plctalk.net/qanda/showthread.php?t=143
I assigned different values to pump(1,2,3) and these numbers I assigned to pump is status of pumps.Now i want to do which comes in first will...
1,608
Hi, Friends doing a program of moeller easy 820-dc-rc plc with MFD-80-B + CP4 HMI display. i need to give the set points in HMI for Cut in and cut...
1,531
Looking over the technical data for a PowerFlex 755 & noticed they specify a minimum enclosure volume for their drives: (1)When using a circuit...
555
Hi all, I am working with an IO link sensor (measuring current across motor)and need to read in and store the sensor values for 5 seconds, then...
1,224
Yes or now and if yes what would you include or test for as a minimum standard? I can think of things like DeMorgan's theorem Karnaugh maps -...
60
23,198
