Modbus TCP/IP vs Ethernet/IP
SpecialK87
Sep 2018
Missouri
49
I am trying to gain an understanding of the 2 communication protocols. I have a device that uses Modbus RTU. It is connected to a Moxa Gateway which converts it to Modbus TCP/IP. If I connect my 1756-L82 to that Moxa device via ethernet, am I then able to communicate to it as if it were Ethernet/IP?
The Moxa gateway you mention must be Modbus TCP sever/ Modbus RTU client. So to answer your question, no, it cannot work as if it was an EtherNet/IP adapter device. But you should be able to achieve the opposite, which is to have the Logix PLC application to act as if it was a Modbus TCP client using some code for this purpose. Perhaps the information in post below may help you.
http://www.plctalk.net/qanda/showthread.php?t=125113
Does anyone have any recommendations for Electronic Circuit Breakers with 0V Terminals built-in and Fieldbus (IO-LINK, MODBUS TCP, EtherNet/IP?)...
196
Hello, Sorry, my knowledge of communication protocol is limited, so thank you in advance for your answer. My question; I want to get 5 values...
867
Hi All, Trying to help a client who has a project that was started with Schneider STB remote I/O, but they are still waiting on the STBNIP2212...
1,917
Hello all, I was wondering if you clever people could help me, please. In the past I have used a standalone L33ER CompactLogix PLC with the...
1,529
Hi all IÂ’m working on a problem in which I have to read sensor data from a data acquisition module in the field that only communicates using...
1,737
