Newbie update and a question or two
caffeinencsu
Nov 2003
I finaly got a working PLC
waaaaaaaaaaaahhhhhhhhhhhhhooooooooooooooooooooo
it was broken, and then on the power up the next it arched, and blew it up, hehehehehehehehehehehe
but I finally have a real live working plc
my question is, I have a machine that sends paper down a ramp from a stack, my problem is I have to send one sheet down the ramp, then stop the next one with a stopper that pops up, send other one down on top of that sheet, drop the stopper and then start the process over again
I am having trouble restarting my counters, and good strategies.
When my counter hits the given value, it causes my relay to latch on, and i just want an impluse, is that possible?
As the problem seems to origin in the PLC program, it would be prudent of you to provide some details.
Such as PLC type and what code you have (attach your code as a zipped file).
First then you can hope for some help on your problem.
Perhaps using a counter to count a value of 1 is not that good.
There is many ways to have this done.
You could latch/unlatch a BIT.
You could ADD 1 to a register and only use the LSB as the memory BIT.
You could filp-flop a rung.
You could make a Start-Stop rung with the 2 papers being the triggers.
You could... you get my point.
I do not use counters for a preset of 1. Has given me too many troubles in the past.
My 2 cents.
Good morning, I've had an inverter fail with firmware revision 5.002, the only spare is Rev 7.001, when updating the project with the new...
1,262
Hello all, I'm a new member here. I've joined as I want to learn about PLC programming. I've got a few questions to begin with. To get me...
37
4,576
Howdy folks. Been doing PLC programming for like 15 years now in LD and ST, but I'm trying to learn SFC now and have a kind of dumb question... I...
1,411
Hello. New to Unity and had a couple quick questions. Can a Modicon M340 output to a small multiline LCD screen and not a full HMI?
967
Hi. I'm learning AOI programming in RSLogix 5000. I created an AOI with several input and output parameters but when I choose the AOI in the main...
17
3,236
