Newbie
nserafini
Dec 2002
Hello all,
A family member who runs a full time PLC design and programming company was kind enough to provide me with a AB SLC5/02 unit w/ input and output modules...
Also, I was given a AB SLC500 1747-PIC device to interface w/ it.
Being totally new, I've been trying to connect to the unit using RSLink, and i'm unable to. ( I'm running RSLogix500 and RSLinx2.2XX on Win XP )
From what I've seen on the web, the PIC unit is an older way to communicate with the device ...
Any advice/ideas/anything on how I can connect to begin learing bus bar design and the like ?
thanks in advance,
Nick
Windows 2000 does not recognize PIC device even through RSLinx. Maybe the same is true for Windows XP?
There is a patch which can fix this problem. Check the Rockwell web side for downloads.
Yep, RSLinx didn't have a 1747-PIC driver available for XP until version 2.31.
You can get version 2.40 of RSLinx Lite from the support.rockwellautomation.com website for free... you'll have to go through the registration process (and it's a way longer download than you'd expect for a set of comms drivers) but it doesn't require a license number.
Hello all, I'm a new member here. I've joined as I want to learn about PLC programming. I've got a few questions to begin with. To get me...
37
4,610
Howdy folks. Been doing PLC programming for like 15 years now in LD and ST, but I'm trying to learn SFC now and have a kind of dumb question... I...
1,425
Hello. New to Unity and had a couple quick questions. Can a Modicon M340 output to a small multiline LCD screen and not a full HMI?
969
Hi. I'm learning AOI programming in RSLogix 5000. I created an AOI with several input and output parameters but when I choose the AOI in the main...
17
3,287
Good morning, I've had an inverter fail with firmware revision 5.002, the only spare is Rev 7.001, when updating the project with the new...
1,268
