newbie
dotolee
Jul 2010
TO
20
hi. i'm playing around with the logixpro 500 simulator to familiarize myself with plc programming.
i'm wondering if someone can tell me the difference between an "output energize" command, and the "latch" command.
what command does one use to "de-energize" an output if you do use the output energize to turn it on? i've figured out the latch/unlatch stuff...
thanks.
thanks.
As long as the rung/input conditions/power flow is true=ouput energized.
As soon as the rung/input conditions/power flow is false = Ouput is de-energized, you don't need to do anything special like an unlatch.
Hello all, I'm a new member here. I've joined as I want to learn about PLC programming. I've got a few questions to begin with. To get me...
37
4,622
Howdy folks. Been doing PLC programming for like 15 years now in LD and ST, but I'm trying to learn SFC now and have a kind of dumb question... I...
1,427
Hello. New to Unity and had a couple quick questions. Can a Modicon M340 output to a small multiline LCD screen and not a full HMI?
970
Hi. I'm learning AOI programming in RSLogix 5000. I created an AOI with several input and output parameters but when I choose the AOI in the main...
17
3,304
Good morning, I've had an inverter fail with firmware revision 5.002, the only spare is Rev 7.001, when updating the project with the new...
1,268
