Omron Mad42 analog card
James Mcquade
Oct 2007
Nashville, Tennessee area
3,691
Hi all,
i was trying to learn the analog card and got pulled off.
now i am asking for your help again.
this is what i have.
all i/o are enabled and set for 0 - 10 volts
all i/o conversion numbers are 0 and 4096
all i/o voltage settings are 0 - 5 volts.
analog 3 input is connected and i can see the data changing in the data viewer screen. the input is connected to an ultrasonic sensor.
at 13" i get an input of 0.067 volts and d102 reads 25
at 6 1/2" i get an input voltage of 9.52 volts and d102 reads 3830.
what i want to do is scale the output to read 0 to 6"
i copied a function block with parameters from another program, but could not figure out how to put in the data numbers.
i also want to scale the data with another instance of the function block that will output 0 - 21 cm for example.
i have looked at youtube videos and i must admit that this is one item that is getting the best of me. omron digital i/o programming is no issue, but the analog,rtd, and thermocouple logic is getting the best of me.
if someone would look at my code and help, i would be ever grateful. any comments and explainations would be appreciated.
thanks in advance.
james
As a note, or clarification, the function block is a template. I would call it ScaleWithParameters or something like that. The Instance you create in ladder will need a unique name like Hot_Water_LVL to be a more specific description of your process.
For each parameter in the instance of your function block, you'll need to choose Insert > Function Block Parameter... I'm not sure why they don't allow a double click to do this.
Hi all, While i am not new to omron, i'm totally new to the analog part and lost. i have a CJ2M cpu 33. then there are 4 i/o cards card 5 is a...
26
2,622
I have little to no experience with Omron. A co-worker is trying to set up a MAD42 Analog I/0 card with a CJ1M CPU 11 on a little trainer unit. He...
2,946
Hi. I have an OMRON PLC CJ1M (cpu 13) with an analog module MAD42. This is my first time working with OMRON PLCs and im having a hard time...
2,642
Hey guys, first time posting here. I am having trouble reading a 0-10V input into the MAD42 module on the Omron PLC. I have already switched the...
2,292
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
78
