panelview 550 AIC slc 5/05
fischb22
Nov 2006
asd
Hi, A while back i found a thread here detailing the setup of a 5/05 for ethernet passthrough on the rs232 port
what i have is a panelview 550, that has 2 dh485 ports, an AIC that is connected to the plc,
i have a copy of the program and need to replace the existing panelview, but i cannot access either panelview from the laptop thru the ethernet, i do not have a real serial port so i cannot hook right up to it
about 2 weeks ago i did manage to connect just fine, and download the existing program, but when i tried to connect today, its not working.
Hi !
you mention that the Panelview has 2 x DH-485 port, plugged to the AIC. ( I assume only one is actually connected !)
How's is this all connected to the PLC, because the 5/05 has: 1 x Ethernet + 1 X RS-232 ....
there must be a RS-232 to DH-485 involved somewhere !
Just a thought: is the communication procotol setted for DH-485, rather than DF1 ?
Setup
Panelview dh485 plug to net-aic+ converter to rs232 on plc
pc to plc via eithernet
i have setup for using dh485 and DF1 with no luck in either configuration.
I have my laptop in the routing table,
i can see the plc in rslinx who, but not the panelview,
i have also tried using an 'empty' program(just the rack config, and channel config..
nothing seems to be working
the file i used last time on the proccessor to do a download, is not doing anything for me this time.
the PV and PLC are able to communicate, i just cant get the pass-through to work
Hi Guys. I am trying to connect a Micrologix 1400 with the Panelview 550 (DH485). The laptop is connected through RS232 on the AIC+, ML1400 with...
35
6,266
I am trying to set up a CompactLogix L35E with a PanelView 550 (2711-K5A2) with the intent of trouble shooting the PLC program before I take it...
3,934
Hello All I am having trouble downloading to a panelview 550 and hope someone here can help. I have the following setup micrologix 1100...
5,150
Hi, I have a panelview 550 2711 B5A1 and a Micrologix 1200 connected to a 1761 NET AIC. Is there a way to communicate between the 6 pin DH485...
3,575
Hi all, Im having trouble transferring a program from one panelview 550 to an new one. I can insert a flash card into the old panelview and upload...
20
357
