PanelView Plus 600 to CompactLogix L32E
OZEE
Mar 2006
Kansas
1,696
I'm working on a new project. Trying to get a new RSViewME app to see my CompactLogix 1769-L32E. I'm alot-rusty with RSViewME.
Problem is that RSLinx Enterprise doesn't give me an option for the L32E. There's an L35E and a bunch of other options, but nowhere is there the processor I'm using. Consequently, I can't get the tags to connect.
All comms are over ethernet. Yes, the ethernet stuff is all configured ok. I can ping everything. I can download from my computer to the PVP. I am online with the PLC.
How do I add the L32E to RSLinx-Enterprise?
Everything appears ok when using "regular" RSLinx.
RSLinx Enterprise should treat the 1769-L32E and 1769-L35E exactly the same. Even if there's no selection for the 1769-L32E in the manually-added hardware list, you should be able to choose the -L35E and have the application work.
Since you describe downloading to the PV+ using RSLinx Enterprise and the Application Transfer tool, you muse be browsing the Ethernet using RSLinx Enterprise. Does the 1769-L32E not show up in the RSLinx Enterprise browse ?
Which edition of RSView Studio are you running ?
It should look like the above. The Ethernet I/P devices are usually 'sniffed out' by RsLinx Enterprise
Make sure the Ethernet Driver is browsing:
It's amazing what an upgrade will do. I had 3.10 - upgraded to 4.00, which we had but I had never installed...
Thanks guys.
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
507
Hello , I have an HMI of PV+ 600 (2711-T6M5D) Ser A Rev B, This HMI doesn't have the ethernet port i have to take backup through communicate...
686
Hello all, I copied the MER file from one PanelView Plus 600 to another one, using a USB drive. On the new HMI, I copied the MER file to the...
663
Hi all, I have an old PanelView Plus 600 (2711PC-T6C20D8) that I am repurposing on our site - I have flashed the firmware to ME version...
1,010
Hello Team, I have a question, I have been working with a panelview plus 600. But I have deleted all the .mer directly from the HMI, after that I...
16
1,773
