Pepperl + kuchs
roxusa
Nov 2008
NJ
994
VBG-ENX-K20-D-EV24 I need help on changing the IP on this unit. I have changed the ML1400 and the IDEC screen but keep getting a fault on this unit
when I configure the new IP. The system was running on the old IP's all I wanted to do was change them so another vendor could access the ML1400
to interface it with his machine. He supplied me with 3 IP's and his Subnet
and Gateway. Each time I load it into the Pepperl+Fuchs and cycle power I come up with an Ethernet Error no comm's.
I have been reading a manual on it and will try and find more info on the web
Any help will be great. I havent tried to set it back to how it was working this morning if all else fails hope to get back running for tomorrow. It is just a short conveyor line.
Hi experts, I hope you're all having incredible days. I'd really like to utilize this sensor for a customer application, but the issue is that...
17
18,866
Hi folks, I had trouble with door switches on a machine I was working on today. What first appeared to be as a simple reed switch turned out to be...
752
Hi, I have a P+F EVS58-PN encoder attached to my S7-1200 in TIA Portal V15. I have my GSD file installed and the device is setup in TIA...
1,937
I'm an AS-i noob. We are the end users of systems. We use outside engineers to develop systems for us. We received a large upgrade to a system...
1,633
Hi guys Using the kfd2 series in a panel, do I need to put +24v on terminals 14 and 15 as well as on terminal 7 to the transmitter? thanks yall
1,563
