Possitive edge inputs with OR gate
manin
Jan 2015
Athens
37
Hello, is it possible to have positive edge inputs in OR gate?
I have 8 inputs and want to trigger Y0, be able to turn off Y0, even if input that triggered is still on..That's ok so far
My problem, is that if another input is being triggered, Y0 must be ON again...
I used positive edge inputs, but simulation does not work that way..
Thanks a lot
I don't know what PLC hardware you are using, not recognising the "Y0" reference, but no, you will not be able to develop an "OR" strategy if you use "edge-triggered" inputs in your program.
Years ago I worked on a Telemechanique PLC that had "static" and "edge-triggered" instructions.....
---| |---- "is it on" ? = a static instruction.
---|/|---- "is it off" ? = a static instruction.
or
---|^|---- "has it just come on" ? = an edge-triggered instruction.
---|v|---- "has it just gone off" ? = an edge-triggered instruction.
Neither of the latter two instructions will be useful in detecting a logical "OR" condition.
Obligatory: Need more info!
I suppose you could start by accompanying each OR condition with a one shot, sealing in the output, I suppose:
|---|-------|IN01 |---ONS---------------| ORBLOCK01 |----------------------------------------( OUTPUT01 )
| |-------|IN02 |---ONS----| |
| |-------|IN03 |---ONS----| |
|----------| OUTPUT01 |--------------------------------|
the other condition, ORBLOCK01, can consist of another set of OR statements consisting of the permissives you require and the |\| of each OneShot bit
ostensibly, I see new edge-triggers re-energizing the rung
I am using Fatek Fbs. Y0 is output 0...I thought that most of manufacturers has Y as outputs.
The triggered instructions are like the one you described
OK...
I have 8 inputs. If one of them is ON then Y0 (siren) is ON.
The user must have the ability to turn off Y0, even if input is still ON.
Now if Y0 is turned off by the user, but input is still on, and another input goes ON, then Y0 is ON again...This is the part I am confused...
I didn't understand your thinkning with ORBlocks
I used this way...It is not the best code, but it does it's work...
If you have any ideas, feel free to share :)
|---|-------|IN01 |-------------------------------------------( MEMORY01 )
|---|-------|IN02 |-------------------------------------------( MEMORY02 )
|---|-------|IN03 |-------------------------------------------( MEMORY03 )
|---|-------|MEMORY01 (Pos. Edg)| ------------------------( MEMORY010 (S) )
|---|-------|MEMORY02 (Pos. Edg)|-------------------------( MEMORY020 (S) )
|---|-------|MEMORY03 (Pos. Edg)|------ ------------------( MEMORY030 (S) )
|---|-------|MEMORY02 (Pos. Edg)|--------OR--------------( Y0 )
|---[in01]--[pos edge]--|--------------------[set y0]--|
|---[in02]--[pos edge]--|
|---[in03]--[pos edge]--|
|---[in04]--[pos edge]--|
|---[ack pb]-------------------------------[reset y0]--|
Like this?
Code:
|---[in01]-|-[pos edge]----------------------[set y0]--|
|---[in02]-|
|---[in03]-|
|---[in04]-|
If that doesn't work:
Code:
|---[in01]--------------|------------------[MEMORY01]--|
|---[in02]--------------|
|---[in03]--------------|
|---[in04]--------------|
|---[MEMORY01]--[pos edge]-------------------[set y0]--|
If one input remains on and another input goes high it is still detected.
I simulated in Fatek and unfortunately it didn't work.
Yes I mean that - it works with Allen Bradley but not all PLCs handle edge detection the same. I've never heard of a Fatek PLC!
That's good to know...I just installed component workbench to practice with it.
Guys, thank you all for your help!!!
I have a FX3U clone that I am failing to get a simple Structured Text example working on and would really appreciate some help. I created a...
30
994
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
322
Hello, I have been tasked with adding some analog signals for display and alarm setup in some old Schneider Electric HMIGTO HMI-panels. I have...
185
Good afternoon everyone, could someone guide me on how to program a falling edge in a wave micro control using CWDesigner? It is to reset a...
134
Can anyone share a way to make a button on the HMI that hits the "Ack Page" in an Alarm and Event Summary Window? or better yet - a plc tag...
269
