Problem conect PLC FX1N-40MT .
phuc0072000
Nov 2020
Ha Noi
Hj everybody , I'm a newbie
I have problem connecting to read the program from the FX1N PLC as shown below.
I use cable USB SC9 , and tested with cable Usb to Com , but both can't conect . I chose the correct COM port , and test connection successful .
I have tried this cable with another device, it can connect.
I use software GX Developer , and GX work 2 .
PLC no have password .
My computer use Win 10 OS 64Bit
If you have experience with this issue, please help me,
thank you very much.!
https://photos.app.goo.gl/wh95Y9riGHKyWGFv9
https://photos.app.goo.gl/oBgwf1BVHbmVZFhJ8
The LEDs, "Power", "ERROR" and "RUN" are not shining, but I/O LEDs are ON so I would say you have PLC malfunctioned. Also, hudging by the color of SC09 it is not original cable. However, I would try to download drivers from MyMitsubishi.
Ronnie, Should not matter as the FX Defaults to 9600 after power up, Both GXDev, Works & Beijers test at this then sends commands to adjust to the selected baud rate, found this out when I talked to Kepware regarding a problem after power up of PLC defaulted to 9600 but GX versions & Beijers would always connect even at 57k. But then again the interface cable does look like a clone & it may depend on the USB to 232 converter being good quality.
The only other time I have had this is wrong parity, stop bits etc. never on baud rate.
All I can say is I've had the same fault and it was making a connection but faulted on upload.
I changed baud and all was well.
Can't harm to try :)
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
40
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
171
Hi, I am having a challenge installing a new drive ACS355-03E-44A0-4 as it keeps on displaying Fault code F00018 even when the load is not...
135
I have an issue on my vessel, we have water tight door system created in China, company is no longer operating. We have 7 doors each with their...
144
Hi all. Simple as simple can be, I don't understand what's happening. I'm toggling he OSR on, GX_LUB_PUMP1_LEAD should switch. It doesn't. The...
27
668
