PV+ to ML1200 comms
naegely
May 2008
Florida
93
I have a ML1200 with 2 serial ports. Channel 0 is configured for modbus communications with a motion controller.
The programming / HMI port is set up for DF1 full duplex (not congigurable).
My question is, is it possible for a PV+ to communicate with the ML1200 via the PV+ serial port to ML1200 prog/HMI port?
I'm not having any luck, the PV+ DF1 node shows up in RSLinx Enterprise (when my laptop is connected to PV+ via ethernet), but no device shows up to create a shortcut.
Thanks for any help,
Rob
Hi all, i have a customer that shuts the power off to the plant several times a year to do work on their substation, consequently all plc's...
1,350
G'day forum! I'm running a 1762-L40BXB (MicroLogix 1200). My issue today is that when I connect using my serial cable (Works on a 1000 and 1100)...
2,710
I need to connect a 2711 k6c9 panelview to a ML1200 PLC. I do have a spare 1761 cbl pm02 cable. What do i need to do to this cable to get the...
2,848
Hey all! Long time reader, first time poster! I have an EA9-T7CL and an MicroLogix 1200 connected via DF1. I'm all good and got everything mostly...
652
Hi every master,Recently i met a fault about 1762-L40BWA 1,When i get the PLC, The Fault light is lighting, I am not remember the fault message,I...
718
