Remote PLC Configuration
Roy Matson
Apr 2004
Vancouver
465
I have been asked to make a few simple programming changes to an Allen Bradley PLC that resides on the other side of the country.
I have been told that it's possible to go on-line via the cell network, is this even possible and if so could someone recommend a pair of modems or a cellphone with data link etc.
The Rockwell software resides on my laptop on this side of the continent.
Someone would monitor progress at the other side, shut down the equipment for safety etc.
The preferred connection to the PLC would be through an existing ethernet switch.
Thanks in Advance
Roy
You can use a unit like this **** http://www.industrialnetworking.com/Manufacturers/****/****-VPN-Router-with-Cellular-Modem-EW4620A
Just make sure the air card you choose is compatible. If they already have something like this then you really just need the vpn info. It is jsut like it being connected toa ethernet network jsut slower.
Most units your usb or express card air card plugs in. Some wired / wireless routers have this option also jsut so the air card can be shared easily.
Hello everybody, I am working for an OEM and we are in the process for trying to raise the effectiveness of the pretesting of machines. Basically...
20
669
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
125
Hello, I have a machine with a 1756-L72 Controllogix PLC and 1756-EN2T network card, and PanelView Plus 7 HMI. I am using RSLogix V20.05.00...
905
Hello All, is there any way to fetch remote controllers Mode Run/Remote Prog/Faulted etc. ( AB L8 Series) using CIP message, if yes please share...
826
Siemens S7/TIA v18: "Remote" updates/bug fixes to PLC code & HMI screens..... Hi, The PLC application I'm working on will soon be delivered to...
587
