RSLogix500 File Sizes
larrybray
Oct 2008
Dublin
This is just a question for curiosity rather than anything else.:confused:
I have two separate autoclaves using the same hardware (SLC 5/04 64K) and the same user program. However, the file sizes are 166kB for one and 330kB for the other.
I've done a compare and the only differnces are the processor name and the data file values. Could this cause the difference in file size?
When I worked at the steel mill, we backed up our PLC files to a 1.44 floppy disk. It was using RS5, but every now and then, our saved file wouldn't fit on the floppy. Would open the file, and re-save; the file size would change drastically in between saves.
In RSLogix500, is there a way to make B3:1/1 to show as B3:0/16? In the below drawing with keyboard letters, --II-- is a rung with a normally...
2,086
Hey all, I have: 30 Float Data File each containing 256 elements. I want to clear the values of all the 30 Data Files, how can I accomplish this...
2,544
Can someone tell me if there is a difference between the B3 file and the B9 file? I was troubleshooting a program that was using a B9 bit and not...
1,873
Greetings to EveryOne: Anyone here has the RSlogix500 software. Attached file is the SLC program that need to be convert to pdf file. Thank you...
2,683
Hi Guys, I have a SLC 503 CPU that I go online with fairly often and never have a problem. Today when trying I got a "No Matching File Found"...
5,755
