RSView32 and PLC5
Kristian
Jul 2008
Guatemala
20
Hello to all, I have an pc running an aplication with RSview32 working with DH+, now I need to move the PC 200mts and there is not DH+ net.
I foun an acces point, so i checked with RSlinx and found the PLC that i was working with rsview32 "CAM00553"
So i decide to work with RSView32 thru the Lan net.
My problem is to configurate the node in RSView32
The image "CAM00555" there is the node configuration
the number 2 to six, is the original configuration. and the 1 is the item that i try to confiurate to reach the "60, PLC-5/60B EMPAQUE" thru ethernet (192.100.10.13)
Any idea what should be the address to reach the "60, PLC-5/60B EMPAQUE" in the "Station" the "Node" in RSView32.
I try to configurate the OPC Server (RSlinx Professional) but I can't do it.
Any idea I'll be pareciate, thanks in advance.
Hello - I need to show PLC5 card status (comms, fault, etc.) in RSView32 and am not sure where to start. Any help would be greatly appreciated...
6,705
Hello, Another problem for me using RSView32 (I am new for this). I will bring the Integer values in the PLC5 converted to a ascii value in a...
4,314
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
377
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,914
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
601
