Kataeb
can we run a Siemens 1PL6 motor direct on line ? by connecting its three power terminals directly to 3x380 vac 50 hz ?
1PL6184-4HF03-0AA3 , SIMOTICS M COMPACT INDUCTION MOTOR; IP 23 OPERATION ON MASTERDRIVES VC/MC CONVERTER WITH EXTERNAL FAN HTL INCREMENTAL ENCODER 1024 P/REV 89 KW, 1750 RPM, 486 NM (VC) TERMINAL BOX ON TOP CABLE OUTLET ON THE RIGHT SIDE DESIGN IM B 35 W/O BRAKE DEEP-GR. BALL B.,VIBRAT. SEV. R SHAFT/FLANGE ACCURACY N FEATHERKEY A. SEMI-WEDGE BALAN. AIR FLOW FROM D-END TO ND-END STANDARD PAINT FINISH: RAL 7016
