S7 PLCSIM - Analogue Simulation
henno2000
Jan 2007
UK
72
Hi, is it possible to simulate analogue values (decimal) for the PLCSIM tool in S7? If so, could someone please elaborate?
Regards,
henno2000
thats one option.
You will have to write a PB or FC anyway to convert the number read from PIW xxx anyway, this is a number between 0 and 27468 (I think)
from example 0 to 10 Volts, 10 volts equals 27468
you can simulate that number in a vat table into a MW adress or so, thats how I do it
If you want your plc program to generate values for the analogue input then you will have to use a DBW or MW value instead of the PIW value in your program. (I have a simulation switch that loads either the PIW value or the simulated DBW value).
Hi I used to be able to launch PLCsim without any problem. Now it tells me " STEP 7 Professional Licence is required to simulate this PLC"...
543
Daft question coming up...When I want to modify a value, what's the best/correct way to do this? At the moment, I am entering the value (e.g...
443
Hi, I want to use PLCSIM because the hardware I was working on has now been delivered to customer. Which option do I choose from this drop-down...
374
hi everyone. i hope you guys are doing great. i am trying to built communication between aveva intouch hmi 2023 and tia portal v18. i dont have...
577
Hi, My PLC hardware has been delivered to customer site - many thanks for the invaluable help on this forum! I was looking into see if it's...
2,532
