Hi Guys,
I am using micro850 PLC (Allen Bradley), the customer requested that all panels should be at one place. So now I have to run control cables to the field.
I have 3 Joysticks, 2 distance measuring Sensors as an Input and 4 Solenoid Valves & 4 LED's as an Output and all of them runs on 24VDC including PLC.
1) What cable gauge (AWG) should I used? ( The cable will be running 50-60 feet from PLC to the field and it will have total 3-4Amp load)
2) The other question is can I used a multiconductor cable (as customer wants to run single cable from panel to field) to control/wiring all the above mentioned devices?
I am thinking of running one multiconductor cable and have a small JB at the field and split that cable's conductors to respective device. Is it possible to do that?
Please let me know if you need additional information.
Thanks.
Thanks.
