Selection of Multiconductor Cable
It's probably overkill. but I would use 14AWG for the power.
This allows for future use, larger power supply for future use, and less voltage drop to begin with.
Maybe even 12AWG
Just curious: Can you not use IO in field similar to armor block? Instead of bringing every signal back to main panel.
Thanks Jim3846
Armor Block is a very good suggestion and will help for shorter cable runs.
But I have never used it before and I am only familiar with its function.
I need an enclosure for wifi access points that will be outdoors. The antennas will mount outside the box but everything else inside. Standard...
159
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
112
Dear Members; We are going to design a Simplex Control System With Following: 1. 24 Digital Inputs (SIL 2) 2. 24 Digital Outputs (SIL 2) 3. 4...
1,140
Respected Members; I am going to design the PLC control system. The requirement as under: 1. Input/ Out put modules are SIL 2 certified. 24...
417
Hello, Not able to find Modicon DO modules BMXDDO3202 in EcoStructure Control expert V15 catalogue. But i can find only MBXDDO3202K. Can you...
472
