Serial port stops sending data...
nikhilec2007
Dec 2014
Gujarat
36
In one of my application with RSView32, I am sending SMS using VBA command and dongle.
When I am testing/debugging code, it runs fine every time.
When triggered same code with events, most of the time it runs well.
But after 7 to 8 triggeres, it stops sending SMSs.
Now, If next event is triggered, it will send SMSs from last trigger as well this trigger.
In between, If i will debug code, then again it will send ALL UNSENT msgs as well debugged VBA sms code.
Earlier I had doubt on dongle, that msgs are some time UNSENT and pending in outbox for dongle. But recently, to troubleshoot, serial port and dongle connection, when I opened HYPER TERMINAL, it started sending all AT COMMANDS, which are generated by my VBA code earlier during VBA Code execution.
From this, I assume, my System is sending all AT Commands on time but sometimes, Serial port (USB) is not sending those AT Commands to dongle.
If anyone has experience this kind of problem in past, please let me know, whether I am right or wrong.
What can I do to eliminate this problem?
All suggestions are welcome..
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
149
I have lm9030 program on my toughbook CF-29 cannot get my program to hook up with the serial port.
73
I need to recommend a PC to replace a customer's old Windows 7 computer. The only thing I need to think through is the serial com port to...
21
705
i have a dell laptop with a real com port host OS is windows 10. Running VB 6.1.42 I cannot get the serial port to configure in VB. Please Help...
1,043
Hi All, I have set up a Moxa NPort serial server for an application. Unfortunately the environment requires NAT forwarding between 2 systems...
833
