siemens 300
Dec 2009
egypt
hi all im working in cement factory and i want to down load the systems from the plc(siemens 313c) into my laptop what type of cable i will need, and i have also used to use V4.0 STEP 7 MicroWIN SP4 to modify and devlop the programs for siemense series 200 is that aplicable with siemense 300 series
thank u all
The cable and software for S7-200 will not work with S7-300.
In this thread is mentioned both the Siemens USB adapter, and a cheaper alternative:
http://www.plctalk.net/qanda/showthread.php?t=52364
The full STEP7 software for S7-300/400 is relatively expensive, but you can download STEP7 LITE for free from Siemens website.
Notice that uploading from a PLC will only give you a program without symbols or comments.
120
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,475
Hello. There is a problem with Siemens S7 300. We got a replacement PLC but it does not run the program from the MMC. The new PLC is dated 2011...
722
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,082
G'day guys, I am setting up a s7-300 as a test rig for the workshop and when I downloaded the PLC is not going into run mode, I keep getting a...
35
5,296
