Siemens S7-300 + PanelView
dmroeder
Apr 2006
Vancouver, WA
3,608
I was wondering if anyone has information off hand on connecting a PanelView (or PV Plus if necessary) to a S7-300 series processor. My company usually just deals with AB, but a customer requested a Siemens processor.
It looks like the 312 comes with 1 RS-485 which I suppose could be converted to RS-232, but we need also need to be online with the processor and have the panelview communicate. AB used to sell panelviews that had Profibus communications built into them, but have discontinued them.
Any help in the right direction would be appreciated!
The PV Plus can communicate to the Siemens Line with the Kepserver drivers that come with RSViewME. (Using the Serial Port included with the STD build HMI)
The successful connections that I've seen use an RS-232 to MPI protocol converter box to communicate with the S7-300 controller.
On the PanelView Plus side you need to add a null-modem adapter or cable to the standard MPI interface serial cable, and of course you're going to run the KepserverEX MPI driver inside the PV+ terminal and on your RSView Studio development computer.
You'll need another MPI/RS232 converter to get your programming computer online with the system at the same time.
Cool, thanks for the reply's everyone. I'll have to dig into the pricing for all that. My company rarely uses Siemens, so I wasn't sure the best way to go. They want everything done as cheap as possible.
Ken, would you happen to know if it's significantly more to go ethernet? We always try to push ethernet, but a lot of the time (with AB) it's not the cheapest route, so they usually shoot it down unless one of our customers requests it.
121
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,478
Hello. There is a problem with Siemens S7 300. We got a replacement PLC but it does not run the program from the MMC. The new PLC is dated 2011...
724
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,082
G'day guys, I am setting up a s7-300 as a test rig for the workshop and when I downloaded the PLC is not going into run mode, I keep getting a...
35
5,306
