Siemens TIA: Block not enabled?
Greet
Aug 2003
Mol
58
Hello,
I have sometimes a problem with a function block: sometimes it looks like it is not enabled (because block is not green). Then, I have indeed a problem with an output of this block.
See picture in attachment.
How can I find what the problem is?
It doesn:t look right. Is the block uptodate in the CPU?
Is this real hardware or PLCSIM?
Is this Schneider's Block for communication with drive?
I don't remember if communication blocks that execute asynchronously do have that behavior, I doubt it.
Is this a cyclic OB, FB or cyclic interrupt?
In a data block, if the tag is ticked in the "Retain" column", is it meant to be retained after cycling the power to the PLC? I'm finding that...
744
I'm having a bad day. Daft question coming up...Anyone know why I can't add anything into this DB? Add button is greyed-out. Thanks
1,609
Using siemens block to control pressure level. The PV is pressure in Bar and the output is vsd fan speed in %. What I require is when the PV is...
3,081
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
458
Hello, If the date on the license manager of tia Portal has expired, can I still work with it? or is this just to keep the program up to date...
224
