SLC 5/05 SQO Instruction
I think they need a better way to trigger the 3 second timer. I was running this yesterday and the .POS did appear to jump from 2-4 and 4-6. That's probably due to it being emulated and in a VM that was probably running low on RAM. Running it today, I can see the steps more clearly.
OG
If the SQO output bits can be indirectly addressed, then why not the TON .PREset as well? The Start/Stop Circuit could be jazzed up to handle the additional logic, and the .PREsets in Data File N254 for steps 2, 4 and 6 would be 900s, 180s, and 300s (15min, 3min, 5min), respectively, but this does pretty much what OP's LAD 6 does.
Back in my tire assembly days, we used a lot of sequencers and often we would use the position value and an array of elements with indirect addressing to load timers for things like maximum or minimum time in a step. Most of ours also used SQI. Eventually I figured out that I didn't like some of the restrictions of the SQI/SQO instructions so I started just using MVM with indirect addressing with external logic to manipulate the step number.
I think I uploaded a generic example to MrPLC many years ago.
Sequencers can be very powerful and were all but necessary to fit the control logic for a complex assembly machine into a PLC with only 4K ram back in the late 70s. But if you don't keep them "clean" and well documented, they can be a bear for the guy who has to troubleshoot them later.
most Sequencers I work on include a timer or counter Preset for that specific step. All written to a single Cycle timer or counter.
I am converting an old SLC 150 program to be used with a newer SLC 5/05. I have done this with other 150s, but I have some instructions that I am...
8,347
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
1,264
I am building a traffic light simulator that I will be using to demonstrate PLC's at my sons' 5th grade elementary school as part of their STEM...
1,766
Can you guys help me understand how the sequencer (SQO) on this program works, please. I see several files that are associated and then I see...
2,739
Can anyone give me an example of using the SQO and SQC functions together Example 2 Pneumatic cylinders Cyl A ext Cyl B extend Cyl B retract Cyl...
3,761
