SLC 500-L20 fixed style controller
gusterminator
Feb 2009
Thunder Bay
85
I was wondering what the advantage is using a 1791-16AC with my SLC 500-L20.
Does this modual replace alot of the terminals I would usually have to use for all my output and input I/O plust power?
I'm building a pannel and am trying to decied if I should use the 1791-16AC or not....I am a beginner. I read the manual and from what I understand once this modual is installed It would feed power and link all the Input and Output deviced to the PLC. Am I correct?
The 1791-16AC is a 'Remote I/O' device. It must be connected to a Remote I/O scanner. The Remote I/O scanner module for the SLC-500 system cannot be used with the L20. It can't be used in any of the 'fixed' type SLC-500 units. Only the 'modular' units may take a scanner module.
Thanks for the reply. So this modual is for controlling a set of inputs and outputs remotely, you would mount it in a pannel without a plc...then run a cable from your remote I/O scanner from your compatable PLC to this modual. Which would be way more convienent than doing a long run of every input and output wire to devices.
I would like to hook my SLC 500 to my Comunication server or hook it directly to my hub RJ45. Does any body know what product I should buy to...
3,472
I'm getting a fault as soon as I put the controller in run. When I go to go to error the plc is saying the problem is Major error halt S:1/13 = 1...
3,420
I'm getting a fault as soon as I put the controller in run. When I go to go to error the plc is saying the problem is Major error halt S:1/13 =...
2,337
I have no prior experience in this PLC field, and I'm hoping to get some help in powering up Allen Bradley fixed controller. 1)Is there any...
8,934
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
992
