SQO LogixPro exercise
sharkyh2o
Dec 2013
Snow Shoe
129
Lancie1, It took me a while to get to this but i finally did. If you could find the time could you check it out. Not sure if this is what the lesson was asking for to load the values to the b3:2 files. Thanks again.I really appreciate it.
have to toggle the stop button to set the input after switching from program to run. i noticed this on the b3:0/0 seal in not dropping out when going to run so i added a first pass xio to drop it. Is this a problem with the simulator and and logic?
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
971
Hello I am trying to make a program work with a sqo instruction .The process has 5 steps ,and a starting step of zero.There should be 8 sec...
17
1,057
I am working on a machine that is using the SQO instruction to step through a cycle, but I am getting lost following it. I have not worked with...
18
3,463
I have an air press that I built ages ago, and it has been running forever. It was originally designed with Rotary Cams and Air actuated buttons...
1,507
Hey guys Having a bit of an issue here. I want my SQO to reset on startup. Im using an (res) on the SQO with the first scan bit with nothing...
1,378
