sqo
Code:
Transfer 16-bit data to word addresses   SQO
Compare 16-bit data with stored data     SQC
Load 16-bit data into a file	    SQL (not used with 5/01, Fixed processors)
Many applications use what is known a Drum Sequncers or cams to initiate actions one after another. The infamous traffic light could use a sequencer...ie the application is sequntial.
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
978
Hello I am trying to make a program work with a sqo instruction .The process has 5 steps ,and a starting step of zero.There should be 8 sec...
17
1,066
I am working on a machine that is using the SQO instruction to step through a cycle, but I am getting lost following it. I have not worked with...
18
3,466
I have an air press that I built ages ago, and it has been running forever. It was originally designed with Rotary Cams and Air actuated buttons...
1,507
Hey guys Having a bit of an issue here. I want my SQO to reset on startup. Im using an (res) on the SQO with the first scan bit with nothing...
1,379
