Syntax to close PV + screen using a macro
skyfox
Nov 2006
CA
279
Panel View+6 1250
FactoryTalk ViewStudio ME Ver. 9
Is there a way to close a PV+ screen using a Macro based on a tag value being changed by the PLC. I do not want to use the global screen close connections as they are bug prone. However, I am ok with using a Global Macro that opens another screen.
In other words,
PLC TAG = A
When A =2 , Panel view macro runs which in turn opens screen xxx. I am using screen ID's on all of my screens. I have done this using a global PLC tag and sometimes Screen change controls does not get reverted back to the touch screen and says screen changes are controlled by the PLC. This is even after the controlling tag value is set to zero. So I am trying to look to do this using a macro.
Anyone knows how to do this?
Thanks.
Hi all. I'm building my first Grafcet using Logix, but I started from another project. From what we usually do with other PLC's, I was expecting...
161
Hi. I'm struggling over some basic stuff here. 41001 I is a 16 bits integer that I'm able to read with InTouch. What I need to do is to read...
96
Hello, Im new to Studio 5000 View Designer and i try to make a popup reusable screen. So i create a user-defined screen with 2...
250
When using the Siemens S7-1200 Symbolic Addressing driver, there is no Offset Tag or Index Option I wish to be able to read an array tag for...
695
Hello, Which syntax I need to use for write on value on a “local tag” that have “Machine” as scope? Thanks
445
