Touchscreen
Mark Buskell
Sep 2003
Florida
892
Is there a distance that you can remote mount a industrial touchscreen monitor from the desktop computer. I have used a splitter before for mounting the monitor remotely (100 meters), but what about the touchscreen part of it. I know the touchscreen acts like a mouse so I am asking do they make a splitter that supports both the monitor and a touchscreen.
Hi!dear
some 2- 3 points are not working in Touch screen of Model HMI E410, can you suggest
(Zombie Thread Alert)
First, try cleaning it thoroughly. I don't know if that is an LED touch array, resistive, or capacitive, but if it's LED, clean the edges.
Then try recalibrating, see here.
If that fails, just replace it.
This is LCD backligt display monocrohm touch screen and its Pen is shifted which needs to calibrate, pls suggest how we do it.
thanks & regards,
JG
My word... a 2004 thread re-animated. That's got to be one of the oldest I've seen brought back to life.
I seem to remember another thread posted by Moses around the same time asking for help fitting a brand new S5 PLC to control the rudders on his ark... ;-)
I don't know what's funnier, the Zombie thread alert, or Moses and the Ark.
Everyone knows Noah was an AB guy.
thanks & regards,
JG
You can recalibrate the screen by rebooting it and then choosing 'control panel' from the menu that pops up (you'll need to be quick to stop it booting into the project).
Somewhere in there will be the recalibrate option. It might be under "OP" or similar if memory serves me.
problem is solved now..... there was a problem of touch screen calibration (pen calibration). In e410 HMI there is one slector switch at right hand side of HMI in back.... will keep it at point no.2 to touch calibration.
thanks
JG
I have 2 PV Plus 7 screens used in the same system that both have touch screens that can be challenging to activate after they haven't been...
585
Hi everyone. I worked with RedLion HMI several years, in the last year four CR3000 HMI (10 and 15") had have problems with the touchscreen. All...
1,282
Every time I power this unit up it loses its IP address and goes to DHCP . When I goto the config the IP address is 0.0.0.0
744
I have a FactoryTalk View ME application that was has been converted to an SE application. I installed it under SE Station version 13 and it...
2,224
Hey All, I'm wondering if anyone has some good tip/tricks for dealing with scratches and scuffs on touchscreens. At this point I'm working on a...
1,420
