USB Port Joystick via opc server to PLC or DCS
Shaun
Nov 2002
I am currently looking at connecting joysticks via usb ports on an HMI PC and sending the joystick position data via an opc server to a PLC. I can't see why this cannot be done. We typically use kepserver, although this application we will be using DeltaV DCS.
Any ideas?
I have a USB port RFID Scanner I am using for badging users into certain access levels in an HMI. I know that I could create a 'login' button that...
613
I am trying to export the alarm history on a Panelview Plus 7 to a USB stick. I cannot get it to write to the USB stick. I have tried the...
6,160
Anyone know if a company makes a 24VDC power supply to USB (C) charger in place of a 120V outlet for programming? I have some panels with 480V or...
21
10,898
Is there an advantage to communicating to CompactLogix with the USB port versus Ethernet? I've always used Bootp to set the IP address on a new...
2,915
Hello, I have an AB PVP 6 with version 10 FactoryTalk ME firmware. I would like it to export the Audit Trail and Alarm History to a USB flash...
2,441
