My boss insists that we use a Siemans 300 series Safety plc for the application of counting and timing pulses at 15 hz 50ms width using 317F-2 CPU SM326 safety input and output modules (DI24xDC24 and DO10xDC24 ) modules we would set a rate and check for pulses that are at a greater rate or intigrate the pulses and drop the outputs if we get too many pulses per given time period. We are new to Siemens had one week class in S7 prog nothing on the safety plc's We use AB SL500's and a few PLC Directs in other proj.
If you use a safety CPU and modules you should be covered.
Not sure what the pulse deal is but that's yours.
Keep in mind that even if you get STEP7 software (I recommend PRO) you will need an add-on package to program safety CPUs.
"S7 Distributed Safety".
And it can be integrated nicely to your Step7.
You'll need WinCC Flex if you intend to do HMI work.
FLEX is the key word here since you can buy the full blown WinCC package that'll do softPLCs and such.
The learning curve can be an issue, especially if you keep "thinking" the AB way.
Read the manuals and practice and you'll be just fine.
EDIT: If by pulses you mean monitoring the safety modules, you don't have to.
They come with build in diagnostics and monitoring tools, the safety CPU takes care of hardware failures and such.
