cheers, hopefully if i can justify the CER for this project then i can take you up on that offer.
does the VPN have to be anything special to allow inter VLAN routing, i know that this is done in the 8300 but didn't know if it needed anything like VLAN Trunking etc
Just has to understand the VLAN Tagging and Trunking Protocols
well my plan was to use a sonicwall firewall and a Cisco router/VPN appliance (887VA) but im going to have a good read on the barracuda if you recommend it.
If you plan to use any Cisco then go Cisco all the way. Be much easier.
i like the techguard unit, the ability to block IP's by country does sound a briliant idea.
Yep why scan and filter and risk traffic you don't need in the first place. This can also be done on most of the newer UTM firewalls also just not as elegant.
I'm guessing you are not fond of Dell?
PC's Yea, Servers Depends, Owning Sonicwall Nope.
i'm interested in the secure crossing you mentioned i have checked out there website and it sounds good, what does this offer ontop of a firewall with deep packet inspection?
Most firewalls work on the principals of signatures and black listing to some degree. Also firewalls block bad data flow.
secure crossing is white list based so it only passes why is know god and blocks everything else by default. It is made specific to sniff industrial protocols like CIP,Profiinet,Modbus TCP,etc.
just a general question but if i have multiple devices with the same things like DPI can these run simultaneously?
Depends but normally in a different way or in a different zone with more or less restrictions.
i have spent probably 20 hours going through videos on youtube, and reading up on different topics which will be needed for this setup, i have been looking at doing some sort of cisco training course, i looked at the CCNA course, is this the sort of thing that would be beneficial or are there other courses that would cover more of the required topics needed for this sort of thing?
