Want Vijeo Designer v6.0 to send ASCII string command to printer
surajchem
Apr 2012
houston
Hi folks,
I am using Vijeo Designer V6.0 to send ASCII string commands to printer.
The printer is an inkjet printer that prints on boxes.
I have to send a string command like this
"SEL|filename|fieldname1|fieldname2|"<cr>
the printer can accept ASCII commands thruogh Serial RS 232 or ethernet TCP/IP.
I can communicate with the printer using a vb code that i wrote to send and recieve commands and acknowledgement.
But the HMI can only send ASCII bytes through serial and modbus tCP/ip. how do i get these 2 to communicate?
Any help would be apreciated
Good Day all. I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x...
182
Hello, I have been tasked with adding some analog signals for display and alarm setup in some old Schneider Electric HMIGTO HMI-panels. I have...
181
Since upgrading to V6.2 12.24 SP12 24-21 the M221 PLC is no longer recognised by the HMI. The screen still works but it does not talk with the...
998
I work for an OEM. I am trying to develop a generic HMI program that will display an overview screen displaying between 2 and 6 "widgets"...
1,312
Hey all, I am using Vijeo Designer v6.2.8.12 for a mineral plant project. For that, I needed to incorporate three different plants' HMI page in...
1,202
