What is DeviceNet & ControlNet?
Bullzi
Jun 2012
Colorado
1,530
Hi everyone,
I am on a quest for knowledge.đź“š Over the years I have become very familiar with RS-232, 485 and Ethernet but have had no experience with ControlNet or DeviceNet. I was hoping that someone on the forum could help me understand what these protocols are.
Here are a few questions that are bouncing around in my head:
What kind of service are they used in?
What kind of standard do they use? RS-485, 232, Ethernet or ??
How does it compare to Ethernet/IP?
What are the advantages/disadvantages of each?
Any other info you would like to offer would be appreciated.
Thanks for helping me understand these items,
Chris
Devicenet is based on the CAN electrical interface, and has a troubleshooting manual as thick as my arm. It maxes out at 512kbps
ControlNet's main advantage that I see is that it is deterministic, as you "schedule" the network, saying "I want this data every 5ms" and the protocol ensures you get the data every 5ms. I'm pretty sure the electrical interface is controlnet specific, but it uses coax cable. You can have redundant networks too, incase one network fails. It maxes out at 8mbps.
I haven't seen any Ethernet/IP devices go over 1Gbps, but most still only do 10/100mbps
I've worked with DeviceNet, but I'm not very fond of it. It is typically used to interface low level devices such as motor starters, relays and limit switches directly to a PLCs shared memory via a bus controller. While it offers significant data exchange, thereby making these low level devices "smarter", it has it's drawbacks. Bulky cable with power on separate conductors means 5 terminations per device in a daisy chain, so you don't really reduce wiring. The baud rate and total node number per network are both rather low. Besides, it only adds another expensive oddball network to your control system to be serviced with proprietary interface equipment. It's a nice system for small OEM packages, I suppose. It was originally developed for use in automobiles.
ControlNet is typically used to connect AB Remote I/O devices such as remote I/O chassis or Flex I/O or to provide a programming interface or peer-to-peer processor communications. It is based upon the fieldbus standard and is basically an upgrade of the old proprietary AB DH+ and RIO networks that ran on "blue hose" twinaxial cable. ControlNet can also serve as a backbone for DeviceNet networks.
correct me if im wrong, but doesnt controlnet also allow connecting some newer allen bradley drives to the plc as well?
or was that devicenet lol
Does anyone know of a cheap USB to ControlNet or USB to DeviceNet adapter (I'm looking for both). I thought PLC Cable would have one but I did not...
16
2,339
I have a Devicenet network that has about 12 Toshiba VFDs that intermittently drops out and the operators are able to immediately re-start the...
1,916
We have a few systems that use DNet and CNet. I noticed there were programs called RSNetWorx which after checking out I see is a topology tool...
3,840
Gents, I have a problem when I want to use the device bridge 1788-CN2DN (controlnet to devicenet). I just wanted to know if someone in here had...
2,662
1,513
