1746-hsce2 card isn't initializing
kchap
Nov 2011
Peculiar, MO
hi everyone. i have 1746-hsce2 card (class 4) that i cannot get initialized. it returns a programming error each time the counter config block is sent. i've gone over my logic and the data values in the block over and over again, but i have not been able to figure out what is going wrong. i'm attaching a screenshot of the module setup and counter config data blocks.
aside from an error in the block or if a counter is enabled when the block is sent, can anyone suggest why this may be happening?
thanks.
i figured it out. i had a rung that had ote instructions for the enable bits in the counter control block. this rung would only go true when initialization would complete without errors. i deleted it, and now the card initializes just fine.
so now i need to figure out how to control the counters without energizing the output bits directly. people are right - the manual leaves much to be desired.
Guys I have a couple of questions about set up of these cards. I have 4 of these in a rack starting at slot 13. 1) Do I need to use intergers N10...
2,110
I have a 1746-hsce2 card located in slot 3 slc rack. The plc is a 5/05. I am needing to read redlion 120 ppr quad encoder The roller it is...
1,324
Hi all I need your help, I have a 1746-HSCE2 card configured, the pulses read perfectly, but I have a problem as I use the pulse counters in...
2,182
Hi everyone. It's been a long time since I have asked for your help but I have been given a heap of plcs cards that have been changed out that...
1,216
I'm a beginner of PLC. Now I have a question. how the high speed counter working in PLC program? I saw some example code. when the program...
1,939
