ab-pic-aic+
tech1
Aug 2011
middlesbrough
tried adding and .starting pic driver on rs linx and it came back with a fatal iniciating fault on driver.anyone know what this means as it will not let you do anything.:mad:
not sure what the message was, but just last week tried to create a pic driver and got error messages, called tech support and it has something to do with windows xp with service pack 3 would not allow me to create and use the driver.
Does your PC have a real serial port? If not you will get that error.
If you are trying to connect to a DH485 controller or network then the 1747-UIC
( USB to DH485 converter ) is your best bet.
yes it has real serial.i also have a new version of rs linx on a new laptop and it does not have the 1747-pic/aic+driver in the drop down box any ideas?
Hello, I am running Windows XP SP2 and Rslinx does not have the 1747 PIC AIC+ driver available. Not showing up on driver list/selections. Is...
4,083
Let me start off by saying I know I need to get a 1747-UIC, but I can't get one in for a couple days and I'm working on something time sensitive...
9,519
I installed RSlinx Lite to a new laptop running on Win 7 and when i tried setting up the drivers, i noticed that there was no driver for...
19,811
Here is the thread that sparked this one. Basically the file serenum.sys seems to be the root of the SP3 issue with the PIC/AIC driver. It needs...
37
45,232
Hi Experts, I've a DH485-network that I want to connect RSLINX to. To be able to do so I've a AIC+-module. I will also need to use the...
5,388
